Community Member
Max power level or the one from site survey
Our site survey report shows 30mW is used for both CCK and OFDM, while our 1240's are shipped w/ default of 100mW / 50mW, CCK / OFDM.
Do you guys recommend changing the power level for both local and client to match the one from the survey?
My options are limited to 25 or 50mW. I can't set it to 30, which isn't given as an option when I try to configure the power level...any suggestions?
1 REPLY
Re: Max power level or the one from site survey
Kevin,
You definetly do not want to set power to max. This will make your cells overlap profusely, and can cause issues. You would be better served by going as close to the power settings on the site survey as possible. If 25 is the closest setting, go with 25, it may mean that you need to adjust AP position, but as we all know, a site survey is only valid until the install takes place.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
128
