measuring the difference in throughput between the "N" radio and "B/G"
We using AIR-LAP1142N-A-K9- AP's and WISM controllers SW 6.0.188.0.
Our Laptops have A/B/G NIC Cards. How do or can I measure
the difference in throughput? How can I tell if we are even
taking advantage of the "N" radio?
1 REPLY
Re: measuring the difference in throughput between the "N" radio
A good and easy way is to use Jperf (Iperf) an grapical tool wich provides you the actual througput of the network. Install this tool on a wired PC and a wireless client.
http://code.google.com/p/xjperf/downloads/detail?name=jperf-2.0.2.zip&can=2&q=
note; JAVA shoud be installed on both wireless client and fixed PC.
279
