Mechanical characteristics of MAR3200 cards
I will use a MAR3200 in a subway environment. Only the FESMIC, MARC and MRPC will be inserted in the enclosure: the WMIC cards will be installed at each train extremity and the SMIC is not required. The allowed space is not huge and the enclosure I will design must be a small sized. I searched information about mechanical characteristics (size, fix points?) for these cards and the associated thermal plates. I am also interested by information about the connectors (type / reference, pins assignment?). Any information or link about these topics will be helpful.
Thanks by advance
Alain-Claude
Re: Mechanical characteristics of MAR3200 cards
On the radio card, there are two ultra-miniature coaxial connectors (U.FL connector) that are used to connect the coax cables between the WMIC and the external antenna connectors. Refer the following URL
http://cisco.com/en/US/products/hw/routers/ps272/products_technical_reference_chapter09186a008022b2e1.html
Hi Shabir,
Thanks for the answer. I know this doc but I need more detailed information about the mechanical characteristics of the MAR3200 cards to define the rack which they will be inserted in.
Best Regards,
Alain-Claude
The cards are PC104 standard, so your best bet is to check out the standards.
Thanks for the answer. Do you have any information about the connectors: location on the PC104 cards, pin assignment, type...
194
