Mesh Backhaul on 2.4ghz
spencerondrusek
Hi I am looking to mesh two 1242 or 2602 access points together.  I am in a mine environment which completely decimates 5ghz signals.  Therefore I need to connect the two APs using 2.4ghz.  Is my only option to buy 1522 APs?  I am currently getting an RSSI of -90 from 5ghz antenna to antenna which works some of the time. My antennas use 15dbi gain and are omnidirectional.  The Mesh AP moves 180 degrees around the Root.
Quote from 1522 documentation version 7.3:
Only 5 GHz backhaul is possible on all mesh access points except 1522 in which either 2.4 or 5 GHz radio can be configured as a backhaul radio
Thanks in advance
0 Replies 0
