Community Member
Migrating from Aironet 4800 to Aironet 1200
There's a page on the 4800 about "Tip". What is it and how does it relate to the config on the 1200?
Here's an excerpt of the 4800's config:
Aironet AP4800E V8.24
warehouse10 -
192.168.000.2
| HOME Help | Configuration | Filter | Diagnostic| Statistics|
| Read Access| Radio Ethernet| | s | |
| Logout | Ident Console | Multicast | | Associatio|
| | Mobile-IP Time | Node | Linktests | n |
| Allow | | | Load | |
| Config | Tip | Protocols | | Logs |
| Changes | | | | |
| Item | Value |
| TIP Server Active | on |
| Type of ARPs to answer | both |
| Display the PTC entries | |
| Add a PTC entry | |
| Remove a PTC | |
| Display the gateway entries | |
| Add a gateway entry | |
| Remove a gateway entry | |
1 REPLY
Community Member
Re: Migrating from Aironet 4800 to Aironet 1200
I've attached the same config in rich text format (use Wordpad) so it can be displayed properly using monotype fonts like Console.
126
