Migrating from VxWorks to IOS - training courses offered
Are there any aids, i.e. courses or Tech Notes, Application Notes, etc. in helping one grasp the change from VxWorks to IOS ?
Thanks.
Greg
Re: Migrating from VxWorks to IOS - training courses offered
Greg,
There is not really a course for this but have you seen these links
http://www.cisco.com/warp/public/102/wlan/AP1200upgrade.html
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_administration_guide_book09186a00801a042e.html
They will give you all the information you need to convert your AP's
Thanks Derwin, I have seen those. What I was hoping for was some type of reference between VxWorks settings and where or how the same things are done in IOS. A simple example for instance, "how to turn off broadcasting the SSID", how to shut down the radio if ethernet connectivity is lost to the AP, etc. In otherwords equal commands under VxWorks and IOS.
There is 2 software configuration manuals one for VxWorks and the second for IOS if you compare the features you are interested in between the 2 you will see them
VxWorks
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/ap120scg/index.htm
IOS
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/b12211ja/b12211sc/index.htm
There is also the command reference for IOS that is an idex for each CLI command
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/b12211ja/b12211cr/index.htm
Thanks again.
Greg
132
