11-07-2003 11:05 AM - edited 07-04-2021 09:08 AM
I am trying to migrate from WEP to a more secure wireless environment using the XP's wireless client. I do not have the luxury of using the Cisco client as the client hardware is not in my control.
I am intending to use the 1100 series access points replacing our early AP340's.
The problem I am having is that all my 340's use WEP key 1 as the sending key. When I try to enable WPA on the 1100 series access point it will not allow me to use key 1. I can use key 2 or 3 and amend the client to look at the appropriate key but that would require a visit to all clients.
My question is, is there any way that you can use both WEP and WPA while maintaining key 1 as the send key for WEP.
I know I can get this to work using VLANs but it seams strange that you cannot use key 1 when you enable WPA.
Thanks in advance
Peter
11-13-2003 08:18 AM
If you need to use both WPA and WEP simultaneously, you cannot use KEY 1 as you said, this is how it has been designed to work.
11-13-2003 10:12 AM
I suspected as much but the question has to be why.
Thanks for the reply,
Peter
11-24-2003 06:52 PM
I'm considering the same migration. Since, encryption and ciphers are enabled on a per-VLAN basis, I'm wondering if I could create two VLAN/SSID mappings, then assign both vlans and SSIDs to the same bridge-group, to put all the WEP and WPA traffic on the same wireless and wired VLANs.
Any thoughts?
04-07-2004 07:20 PM
