Mobile IP and WLAN
I have a ISR with Mobile IP configured, one of its Ethernet interfaces is roaming. This mobile router also has a WLAN controller module in it.
How do I go about setting up and configuring the WLC module and LAP for mobile IP, so that I can have Wifi access to the mobile router? My actual intention is to examine the handover of the MR between Ethernet and Wifi.
Thanks!
Re: Mobile IP and WLAN
I am not sure if I get the question correctly:
You have an ISR and you would like to use it as a Mobile-Node? How is the ISR roaming on its ethernet interface?
Maybe put a topology so it becomes a bit more clear what you are testing?
Serge
I'm not sure to know about mobile IP on wired devices, but maybe this can help ?
http://www.cisco.com/en/US/partner/docs/solutions/Enterprise/Mobility/emob41dg/ch12MoIP.html
Nicolas
245
