04-03-2009 01:21 AM - edited 07-03-2021 05:24 PM
I have 2 1240 in bridge. I need to transport on that bridge 3 vlan. I create 3 SSID , I see the dot11 association on both the AP but if I try to ping the remote it doesn't work.
Any suggestion?
Thank you in advance
Giovanni
04-03-2009 06:47 AM
Hi Giovanni,
When in bridge mode, APs only need a single SSID to carry all VLANs. Delete two of the SSIDs, and remove the VLAN configuration from your remaining one. Be sure to configure "infrastructure-ssid" under the "dot11 ssid SSID_NAME" sub-command line.
You'll still need to make sure that you have the proper subinterfaces and bridge-groups. Let me know if that works, and if not please feel free to post your configuration and we'll get it resolved.
Jeff
04-07-2009 04:54 AM
Thank you Jeff,
unfortunately I have to go at the customer site for the test. I will update this conversation as soon as I have news.
Giovanni
04-17-2009 04:45 AM
Hi Jeff,
finally I can do some test with your suggestion but I don't able to obtain that the bridge carry all Vlan. Only Vlan 1 works.
I attach the config of both the AP.
hostname BridgeRoot
dot11 ssid Bridge1PR
authentication open
authentication key-management wpa
infrastructure-ssid
wpa-psk ascii pippo
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid Bridge1PR
antenna transmit right
antenna receive right
channel 2412
station-role root bridge
world-mode dot11d country IT outdoor
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
interface FastEthernet0.130
encapsulation dot1Q 130
no ip route-cache
bridge-group 130
no bridge-group 130 source-learning
interface FastEthernet0.344
encapsulation dot1Q 344
no ip route-cache
bridge-group 244
no bridge-group 244 source-learning
bridge 1 protocol ieee
bridge 1 route ip
hostname BridgenoRoot
authentication open
infrastructure-ssid
wpa-psk ascii pippo
bridge irb
no ip address
no ip route-cache
ssid Bridge1PR
station-role non-root bridge
bridge-group 1
no bridge-group 1 unicast-flooding
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 130
no ip route-cache
bridge-group 244
bridge 1 route ip
I done some test with different configuration but always only the Vlan 1 was OK.
Giovanni
04-17-2009 05:15 AM
To fix:
vlan 1
no encryption mode ciphers aes-ccm tkip
encryption vlan 1 mode ciphers aes-ccm tkip
interface Dot11Radio0.1
encap dot1q 1 native
bridge-group 1
interface Dot11Radio0.130
encap dot1q 130
bridge-group 130
interface Dot11Radio0.344
encap dot1q 344
bridge-group 244 !note typo matches current configs
04-17-2009 07:00 AM
Thank you, it's work!
Giovanni
