09-13-2013 12:08 AM - edited 07-04-2021 12:49 AM
Does anyone know how to upgrade license from MSE 7.3 to MSE 7.5 or we need to buy new ones?
Thank you.
Solved! Go to Solution.
09-13-2013 03:34 AM
The license has changed from MSE v7.3 which you have. On v7.4 it has changed to AP counts which is on the honor system to use. On v7.5, the license is mandatory to buy. On your version it was based on elements and now on v7.5 its based off of APs. The ration is 50 elements per AP.
09-13-2013 07:03 AM
Contact you AM. They will assist you getting your licenses adjusted in the new model.
09-13-2013 03:22 AM
Hello Kirill,
The MSE licenses are based on number of access point not on the MSE software code. Licenses are additive. You just need to upgrade your code. Follow the two below links
http://www.cisco.com/en/US/prod/collateral/wireless/ps9733/ps9742/data_sheet_c07-473865.html
http://www.cisco.com/en/US/docs/wireless/mse/3350/release/notes/mse7_0_201.204.html
09-13-2013 05:58 AM
Thank you, I know it.
I must update mse from 7.3 (with license 3000 tags) to mse 7.5 which will convert my license to 60 ap, but i have 560 APs. How i can purchase support for all my access points?
09-13-2013 03:34 AM
09-13-2013 03:38 AM
+5 for Scott
09-13-2013 04:02 AM
Haha... I just went thought that with a customer of mine yesterday:)
09-13-2013 07:03 AM
