MSE and Prime
Dear All
Could any one tell me the step by step procedure of integrating MSE with prime..?
And also what is the minimum version is required on Prime or dependencies if any.
Thanks in advance
KVS
VIP Purple
MSE and Prime
Here is the Prime /MSE compatibility matrix.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp113696
Regarding to adding MSE to your prime, you can do that via prime GUI
Services -> Mobility Services Engine -> Add Mobility Services Engine -> Go
You have to enter MSE name/IP & username/password configured for MSE/Prime communication when setting up MSE. Once added, you need to synch WLCs & MAPs onto MSE.
Rasika
***** Pls rate all useful responses *****
MSE and Prime
Any special config for WiPS and RTLS..?
VIP Purple
MSE and Prime
Here is wIPS deployment guide for MSE 7.4
http://www.cisco.com/en/US/docs/wireless/technology/wips/deployment/guide/WiPS_deployment_guide.html
This provides location services implementation guide
http://www.cisco.com/en/US/prod/collateral/wireless/ps9733/ps9742/guide_c07-726506.html
Here is the 7.5 config guide with respect to CAS (Context Aware Services)
http://www.cisco.com/en/US/customer/docs/wireless/mse/3350/7.5/Cisco_Connected_Mobile_Experiences/Guide/7_4_MSE_CAS_chapter_01010.html
Rasika
MSE and Prime
Thank you so much Rasika
247
