Multi-WLAN: Clients don't find AP, can't call 7920
Hi!
We use some Aironet 1200 AP's with a dot1q-trunk and four SSID's. The first ist our guest-vlan with enabled beacons. The second and third is four a different company in our buliding (we provide LAN service for them). The fourth is for mobile voice-over-ip (with
Cisco IP-Telephony).
We have now two problems with this scenario:
- The PCI-Wireless-Cards of our customer don't find
the AP (only the beacon-net). But we configured
the network manually with ssid and wep-key in
WinXP and Win2k (D-Link and Netgear-Cards).
With my notebook and Orinocco-Card it works fine.
- The IP Phone 7920 registered at CM (manually
configured SSID and WEP) and I can call-out. But
call-in to the phone work only somethimes. Mostly
I can't call this phone. I get a call tone one or
two times and then a busy. The 7920 doesn't ring
and afterwards it search for an AP and does a new
registration there. Off course before I called the
phone it was already registered.
Do you have a solution for this problems?
regards Markus
  • Other Wireless - Mobility Subjects
Re: Multi-WLAN: Clients don't find AP, can't call 7920
I can only maybe help you with the first problem: maybe the client cards does support only broadcast ssid and it doesnt matter if you enter the ssid in the OS. that could be the problem i had the same issues with Linksys usb clients.
the second problem: i cant help you we also use the 7920 within vlans and it workes fine.
regards Bernhard
Thank you for your answer. Ok, I will check this with these adapters.
Now the voice-problem. We use CM 3.3 and 7920 firmware 1.0. Here is my AP-Configuration. Mybe it would help someone. IOS-Version is unknown because I am currently out of office.
regards Markus
ip ssh time-out 60
ip ssh authentication-retries 2
dot11 holdoff-time 600
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 224 key 1 size 128bit --- transmit-key
encryption vlan 224 mode wep mandatory
encryption vlan 222 key 1 size 128bit --- transmit-key
encryption vlan 222 mode wep mandatory
ssid airNet
vlan 11
authentication open
guest-mode
ssid bme
vlan 34
authentication open
ssid newv
vlan 224
authentication open
ssid voip
vlan 222
authentication open
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2312
station-role root
no cdp enable
interface Dot11Radio0.1
description -- native-vlan fuer dot1q-trunking only --
encapsulation dot1Q 1 native
no ip route-cache
shutdown
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.11
description -- airNet -- SSG --
encapsulation dot1Q 11
no ip route-cache
no cdp enable
bridge-group 11
bridge-group 11 subscriber-loop-control
bridge-group 11 port-protected
bridge-group 11 block-unknown-source
no bridge-group 11 source-learning
no bridge-group 11 unicast-flooding
bridge-group 11 spanning-disabled
interface Dot11Radio0.34
description -- bme --
encapsulation dot1Q 34
no ip route-cache
no cdp enable
bridge-group 34
bridge-group 34 subscriber-loop-control
bridge-group 34 block-unknown-source
no bridge-group 34 source-learning
no bridge-group 34 unicast-flooding
bridge-group 34 spanning-disabled
interface Dot11Radio0.222
description -- voip --
encapsulation dot1Q 222
no ip route-cache
no cdp enable
bridge-group 222
bridge-group 222 subscriber-loop-control
bridge-group 222 block-unknown-source
no bridge-group 222 source-learning
no bridge-group 222 unicast-flooding
bridge-group 222 spanning-disabled
interface Dot11Radio0.224
description -- newv --
encapsulation dot1Q 224
no ip route-cache
no cdp enable
bridge-group 224
bridge-group 224 subscriber-loop-control
bridge-group 224 port-protected
bridge-group 224 block-unknown-source
no bridge-group 224 source-learning
no bridge-group 224 unicast-flooding
bridge-group 224 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet0.1
no ip route-cache
no cdp enable
bridge-group 1
interface FastEthernet0.11
no ip route-cache
no cdp enable
bridge-group 11
interface FastEthernet0.34
no ip route-cache
no cdp enable
bridge-group 34
interface FastEthernet0.222
no ip route-cache
no cdp enable
bridge-group 222
interface FastEthernet0.224
no ip route-cache
no cdp enable
bridge-group 224
interface BVI1
no ip address
no ip route-cache
shutdown
interface BVI11
description -- Management-Int im airNet --
ip address x.x.x.x 255.255.255.0
no ip route-cache
ip default-gateway x.x.x.x
no ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
access-list 10 permit x.x.x.x
no cdp run
bridge 1 route ip
bridge 11 route ip
line con 0
password ---
line vty 0 4
access-class 10 in
password ---
login local
history size 100
transport input ssh
line vty 5 15
access-class 10 in
password ---
login local
history size 100
transport input ssh
end
178
