Multiple SSID on air-sap2602
waqas sardar
Dear Team,
I am configuring air-sap2602 and created multiple ssid but  its broadcasting  only one ssid instead of multiple.Any one can help me?
Hi Waqas,
You may be missing "mbssid guest-mode" command under SSID configuration & "mbssid" command under radio interfaces. Since it is multiple SSID you require this.
Here is a sample configuration of two SSID (WLAN-1 with vlan 7 & WLAN-2 with vlan 8) & AP management (on vlan 10). Security configuration used WPA2/AES with PSK
hostname AAP1
dot11 ssid WLAN-1
   vlan 7
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii WLAN-1-KEY
   mbssid guest-mode
dot11 ssid WLAN-2
   vlan 8
   authentication open
   wpa-psk ascii WLAN-2-KEY
   mbssid guest-mode
interface Dot11Radio0
encryption vlan 7 mode ciphers aes-ccm
encryption vlan 8 mode ciphers aes-ccm
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
interface Dot11Radio1
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
interface Dot11Radio0.7
encapsulation dot1Q 7
bridge-group 7
interface Dot11Radio0.8
encapsulation dot1Q 8
bridge-group 8
interface Dot11Radio0.10
encapsulation dot1Q 10 native
bridge-group 1
interface Dot11Radio1.7
bridge-group 7
interface Dot11Radio1.8
bridge-group 8
interface Dot11Radio1.10
bridge-group 1
interface GigabitEthernet0.7
bridge-group 7
interface GigabitEthernet0.8
bridge-group 8
interface GigabitEthernet0.10
bridge-group 1
interface BVI1
ip address 192.168.10.254 255.255.255.0
ip default-gateway 192.168.10.1
Here is AP connected swtichport configuration. SVI configuratoin & DHCP configuration to be there (not shown here)
**** AP Connected Swtichport *****
int g x/x
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allow vlan 7,8,10
Rasika
**** Pls rate all useful responses ***
6 Replies 6
Sandeep Choudhary
can you paste the config here , then only we can find the cause.
Reagrds
Hi Waqas,
hostname AAP1
dot11 ssid WLAN-1
   vlan 7
   authentication open
   mbssid guest-mode
dot11 ssid WLAN-2
   vlan 8
   authentication open
   mbssid guest-mode
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
bridge-group 7
bridge-group 8
bridge-group 1
bridge-group 7
bridge-group 8
bridge-group 1
bridge-group 7
bridge-group 8
bridge-group 1
interface BVI1
int g x/x
Rasika
Hi Rasika,
With mbssid guest-mode command both of wireless SSIDs work in guest mode? Can I use both of SSIDs in my internal network for two parties?
Thank you
Kind regards
Chamara
Hi Chamara,
Guest mode broadcasts the SSID and only one SSID can be in gueat mode.
To broadcast multiple SSIDs use mbssid guest-mode on each SSID.
Check the example:
http://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-autonomous-ap/
Dont forget to rate helpful posts
Thanks for the reply Sandeep. But my question is are those two SSIDs can use as non guest wireless for my office use
thank again bro
Kind regards
Chamara
of course you can use both ssid of office use.
Its depends on your configuration.
