02-24-2012 10:28 AM - edited 07-03-2021 09:39 PM
I have three AP but one one is connected with a network cable and the other work on a repeater mode.
I need to create two vlans which will broadcast two ssid one for office and one for guest. I know you can't create multiple vlan on a repeater but is there any way round then with only one AP which connected to the network and other working in repeater mode?
02-24-2012 10:39 AM
There is not due I the fact that traffic will be places on the vlan the repeater is associated to. If you had a wlc, you could do indoor mesh and be able to do what you want.
Scott Fella
Sent from my iPhone
02-24-2012 02:24 PM
Sorry Scott,
I don't really understand your response, I know what in a repeater mode there needs to be one native vlan and only one therefore I am not able to have one guest and one office ssid broadcasted from the repeater.
02-24-2012 04:45 PM
You can probably is you configure one radio as a repeater and the other radio for client access, but they will be placed on the same subnet which is your native vlan. I'm not 100% sure that would work anyways, but I know you can't separate the traffic.
Scott Fella
Sent from my iPhone
02-25-2012 12:57 AM
If that’s the case I am not able to place them on a different subnet and then allow the repeater to the router, i.e. both subnet would appear in the routing table, it this possible?
You mention using mesh mode, how would I go by implementing this?
