Native VLAN on wired switch and wireless AP
On our 3560g switch we have g0/15 set up as a trunk to connect our wireless AP.
Port Mode Encapsulation Status Native vlan
Gi0/15 on 802.1q trunking 35
Port Vlans allowed on trunk
Gi0/15 1-4094
Port Vlans allowed and active in management domain
Gi0/15 1,10-14,18,20,22,30,35
Port Vlans in spanning tree forwarding state and not pruned
On my AP I have the native VLAN as 1.
From my reading I found that the AP and the switch port should have the same Native vlan on both ends of the trunk. Well my access point will not work unless the AP trunk is on 1 and the switch is on 35. Any ideas?
Re: Native VLAN on wired switch and wireless AP
When you are setting the IP address on the BVI interface, are you using an address in the vlan 35 subnet? If you could post a copy of the config of the AP that will help as well.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
dot11 ssid guestwifi
vlan 20
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
dot11 ssid nwifi
vlan 35
guest-mode
dot11 arp-cache optional
c
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
encryption vlan 35 mode ciphers aes-ccm tkip
encryption vlan 1 mode ciphers aes-ccm tkip
encryption vlan 20 mode ciphers aes-ccm tkip
ssid guestwifi
ssid raydonwifi
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
no dot11 extension aironet
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio0.35
encapsulation dot1Q 35
no ip route-cache
bridge-group 35
bridge-group 35 block-unknown-source
no bridge-group 35 source-learning
no bridge-group 35 unicast-flooding
bridge-group 35 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption mode ciphers tkip
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
channel 5200
station-role root bridge
antenna receive right
antenna transmit right
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.20
no ip route-cache
bridge-group 20
interface FastEthernet0.35
no ip route-cache
bridge-group 35
interface BVI1
ip address 192.168.35.12 255.255.255.0
no ip route-cache
ip default-gateway 192.168.35.1
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
access-list 111 permit tcp any any neq telnet
snmp-server community home RO
snmp-server enable traps tty
control-plane
bridge 1 route ip
line con 0
access-class 111 in
transport preferred all
transport output all
line vty 0 4
access-class 111 in
transport input all
line vty 5 15
access-class 111 in
transport input all
end
Shannon,
What you need to do is, remove all the .1 interfaces, and put all the .35 interfaces into bridge-group 1, and mark them with dot1q 35 native. Otherwise you have a mismatch between what the AP thinks is native, what subent the BVI belongs to, and the native vlan on the trunk port. The only requirement here, is that you have a bridge-group 1, it can be on any subinterface, so long as it is the native vlan for the AP.
173
