Need help with troubleshooting on 1200
I have set up a 1200 (image c1200-k9w7-tar.123-7.JA) with multiple SSIDs, one of which is intended to be completely open;
dot11 ssid bfopen
vlan 69
authentication open
guest-mode
This works perfectly for most clients (Windows, Linux) but a HP IPAQ rx3715 will not maintain an association. It sees the SSID and tries to connect but the association drops after a matter of seconds. The DHCP server on that VLAN sees a request from the IPAQ and replies, but by then the connection is gone.
I did some debugging on the 1200 which shows the following;
Nov 14 16:14:28.848: dot11_mgr_disp_wlccp_update_auth: unknown auth type 0x1
Nov 14 16:14:28: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0012.7999.ded8 Associated KEY_MGMT[NONE]
Nov 14 16:14:36.682: dot11_dot1x_gtk_update_on_disassociate: Recieved gtk update notice due to disconnect for 0012.7999.ded8 on vlan 69
Nov 14 16:14:36: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0012.7999.ded8 Reason: Previous authentication no longer valid
Nov 14 16:14:36.688: dot11_mgr_disp_wlccp_update_auth: unknown auth type 0x1
Nov 14 16:14:36: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0012.7999.ded8 Associated KEY_MGMT[NONE]
Nov 14 16:14:42.561: dot11_dot1x_gtk_update_on_disassociate: Recieved gtk update notice due to disconnect for 0012.7999.ded8 on vlan 69
Nov 14 16:14:42: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0012.7999.ded8 Reason: Previous authentication no longer valid
Nov 14 16:14:42.567: dot11_mgr_disp_wlccp_update_auth: unknown auth type 0x1
Nov 14 16:14:42: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0012.7999.ded8 Associated KEY_MGMT[NONE]
Nov 14 16:14:49.567: dot11_dot1x_gtk_update_on_disassociate: Recieved gtk update notice due to disconnect for 0012.7999.ded8 on vlan 69
Nov 14 16:14:49: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0012.7999.ded8 Reason: Previous authentication no longer valid
[loads more entries exactly like these...]
I really need help in identifying why this client has problems but all the others are OK. Can anyone suggest what more I can do to identify why this client is constantly being deauthenticated?
Colin
Re: Need help with troubleshooting on 1200
What are the radio preamble settings on your access point?
Cheers,
Pablo
What are the preamble settings on your access point?
Cheers,
Pablo
Pablo,
Radio preamble is set to Short (default). Other settings are;
traffic-class background cw-min 5 cw-max 8 fixed-slot 3
traffic-class best-effort cw-min 5 cw-max 8 fixed-slot 2
traffic-class video cw-min 4 cw-max 6 fixed-slot 2
traffic-class voice cw-min 3 cw-max 7 fixed-slot 2
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 10
power local ofdm 10
power client 10
packet retries 32
fragment-threshold 2338
station-role root
rts threshold 2339
rts retries 32
beacon period 4000
no dot11 extension aironet
no cdp enable
infrastructure-client
Colin
Hi Colin,
It could be the wireless card you are using on the IPAQ rx3715 that doesn’t support short preambles. Change the radio preamble to short and see what happens, if your WLAN is not heavily utilize this change shouldn’t impact much of the performance. Let me know...
Thk,
Pablo
I have just changed the Preamble from Short to Long, but the behaviour is still the same. Looking at the iPAQ, it sees the SSID, associates with it (signal about -50dBm), and then a couple of seconds later it has no signal. A couple of seconds later it sees the SSID and this just goes on and on. The AP is about 2 or 3 metres away from me.
What's worse is that I can't get the AP to show me anything useful using the debug commands. I am connected to the console and have the following debug set;
Dot11Radio 0
Receive packet trace will print
Transmit packet trace will print
Beacons will be displayed
Probe request/responses will be displayed
Ack/Cts/Rts will be displayed
Crc errors will be displayed
PLCP header will not be displayed
IV will be displayed
CKIP MIC will be displayed
only last 3 bytes of mac addresses printed
Entire packet will be displayed in hex
2 lines of packet data will be displayed
dot11:
IEEE 802.11 packets debugging is on
beacon and probe reponse debugging is on
But I see no output exept the the usual;
Dec 1 17:09:06: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0012.7999.ded8 Associated KEY_MGMT[NONE]
Dec 1 17:09:12: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0012.7999.ded8 Reason: Previous authentication n
o longer valid
Dec 1 17:09:12: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0012.7999.ded8 Associated KEY_MGMT[NONE]
Dec 1 17:09:19: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0012.7999.ded8 Reason: Previous authentication n
o longer valid
Any suggestions gratefully received.
Colin
481
