Community Member
Need to implement Fast Secure Roaming; Does Win2K IAS support this?
I have configured Wireless Domain Services on an access point, in addition to IAS on a Win2K server. The AP has been configured with a username and password for the infrastructure authentication, but the authentication fails on the IAS server with the error, "The specified authentication type is not supported on this system." Within the IAS server profile, all authentication types are selected along with EAP/PEAP. From a 2004 Networks presentation, I saw that Fast Secure Roaming requires LEAP or EAP-FAST, which are both Cisco protocols. I presume the authentication is failing because of this issue. Does anyone know if it is possible to use IAS on a Win2K server, or possibly is there a way to use the local RADIUS server on the AP? Thank you.
1 ACCEPTED SOLUTION
Silver
Re: Need to implement Fast Secure Roaming; Does Win2K IAS suppor
the AP uses port 1812 and 1813 for RADIUS instead of 1645 and 1646. Swap that out, and your config looks almost identical to the one I have archived.
Silver
I do not believe IAS can support it, but I have used the local RADIUS server on APs to do CCKM in the past. I would not do it if there are a lot of users, but my deployments were just a few APs and a few VoIP phones and it worked fine with eap-fast.
Community Member
Can you check the attached configuration with your configuration? The local RADIUS looks straight-forward, but my logs keep showing the following:
Sep 15 16:59:36.423: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.1.80:1645,1646 is not responding.
Sep 15 16:59:36.423: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.1.80:1645,1646 has returned.
Sep 15 17:00:46.193: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.1.80:1645,1646 is not responding.
Sep 15 17:00:46.193: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.1.80:1645,1646 has returned.
Thanks again.
version 12.3
no service pad
service password-encryption
hostname AP1
enable secret 5 ********
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
server 192.168.1.80 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius Infrastructure
aaa group server radius Client
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login method_Infrastructure group Infrastructure
aaa authentication login method_Client group Client
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid Epworth
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa cckm
crypto pki trustpoint TP-self-signed-3104825495
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3104825495
revocation-check none
rsakeypair TP-self-signed-3104825495
crypto ca certificate chain TP-self-signed-3104825495
certificate self-signed 01
quit
username ************ privilege 15 password 7 ************
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid Epworth
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2417
station-role root
antenna gain 5
world-mode legacy
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.1.80 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.251
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
no authentication mac
nas 192.168.1.80 key 7 06160E325F59060B01
user ************ nthash 7 ************
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.1.1 auth-port 1645 acct-port 1646 key 7 095C4F1A0A1218000F
radius-server host 192.168.1.80 auth-port 1645 acct-port 1646 key 7 03145A1815182E5E4A
radius-server vsa send accounting
control-plane
bridge 1 route ip
wlccp ap username ************ password 7 ************
wlccp authentication-server infrastructure method_Infrastructure
wlccp authentication-server client any method_Client
wlccp wds priority 254 interface BVI1
line con 0
line vty 0 4
end
AP1#
Silver
Community Member
Yes, this fixed the problem. The system is up and running.
By the way, how do you mark problems as solved?
Silver
Glad to hear.
Next to all posts is an option to "rate this post" with a 1-5 points available. I believe there is also an option to mark this post as solving your problem, but I haven't asked a question lately, so I don't know exactly what it says.
Community Member
Im looking at a similar architecture with the same questions.
Its not clear to me from your post how this was resolved and whether changing the ports on which the radius server listens will permit EAP-authenticated clients to roam between access points.
Could you clarify/explain:
-Are you trying to get EAP clients to roam between access points using IAS?
-Was the change of ports the key?
-Any idea why?
Would you be willing to share your config?
Community Member
I was initially going to use IAS, but the client didn't have the servers up yet. I ended up authenticating user based on local accounts on the wireless APs (RADIUS was set up on the APs), and the RADIUS server on the APs run on ports 1812 and 1813, not on what is normally used by, say, a Windows IAS RADIUS server (which is the default port used by the APs).
Community Member
Thanks for the reply.
Now its clear what you meant. Well if it helps anyone else I did try a brief test and the results show that an intel client connected either with PEAP or WPA-PSK
Bronze
IAS does not support either LEAP or EAP-FAST. You can use the local RADIUS server on the AP. Note that CCKM is supported with ALL EAP types with CCXv4 clients, provided you're using a supplicant that supports it.
190
