Hi all,
I'm trying to find solution for mobile vehicle. The base wifi system is lwapp with controller and AP.
I was thinking to make bridge between LWAPP AP's and Autonomous AP on the mobile vehicle with client behind the AP, but now the vehicle will have 3 clients so I will have to put something behinds so I will have to put switch behind
does that solution seels good or does I need to choose wifi router ?
according to me keep an Autonomous AP was good idea.
is it possible to make the AP works with PEAP and other high level security like EAP-TLS and more ?
thanks in advance
hope you will tell me your opinion
Matt
