05-28-2009 09:36 AM - edited 07-03-2021 05:39 PM
I manage a deployment of several hundred APs, almost all of them 1242ag and the last few that were added to the system have been coming up strangely in WCS. The controllers seems to recognize them but I have gotten warning messages that they are in the wrong rf domain in WCS. I also see that most show up with blank model numbers, ap type "unknown" and no serial number listed. When I go into the individual radios I can not configure the antenna by model number. They appear normally in the 4404s but not in WCS. I am at a loss as this functionality is only lost on the last 10 aps I have added to the system and they are recognized in the 4404 controllers they are landing on.
06-03-2009 06:19 PM
verify the configuration with this one:
version 12.4
no service pad
hostname WGB
logging buffered 200000 debugging
enable secret 5 $1$xPtX$hjxzdWVR9qa4ykoxLYba91
no aaa new-model
clock timezone MST -7
dot11 ssid EAPTLS
authentication network-eap eap_methods
authentication key-management wpa version 1
dot1x credentials EAPTLS
dot1x eap profile EAPTLS
infrastructure-ssid
power inline negotiation prestandard source
eap profile EAPTLS
method tls
crypto pki trustpoint COPY-PASTE
enrollment terminal
subject-name CN=WGB
revocation-check none
rsakeypair manual-keys 1024
crypto pki certificate chain COPY-PASTE
certificate 1379B07200000000000C
quit
certificate ca 612683248DBA539B44B039BD51CD1D48
quit
username WGB
pki-trustpoint COPY-PASTE
username Cisco password 0 Cisco
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid EAPTLS
packet retries 128 drop-packet
station-role workgroup-bridge
no dot11 qos mode
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
sntp server 10.0.47.1
end
