Community Member
New AIR-LAP1142N-A-K9 Insufficient Memory To Boot The Image
I'm hoping someone can help me with this as I just pulled the AP out of the box and haven't received support contracts yet.  I connected the AP to the LAN and added it to my 4402 controller (version 5.2.178.0) with no problems.  Once I set it the mode to H-REAP and it rebooted, it went loopy.  Actually, it boots up, shows a bunch of debug info, then reboots.  The console output is below.  I've tried reimaging (image c1140-rcvk9w8-tar.124-21a.JA2.tar) but still have the same problem.  I checked and although the controller software is old, the AP is supported.  Would this be a hardware issue?
Thanks in advance,
Bill
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(18a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 23-Jan-09 19:54 by prod_rel_team
ap uptime is 6 seconds
cisco AIR-LAP1142N-A-K9    (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FTX1446E1TQ
PowerPC405ex CPU at 586Mhz, revision number 0x147E
using  eeprom values
WRDTR,CLKTR: 0x88000800 0x40000000
RQDC ,RFDC : 0x80000038 0x0000020a
ddr init done
IOS Bootloader - Starting system.
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x88000800, 0x40000000
RQDC, RFDC : 0x80000038, 0x0000020a
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 8 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 6482944
flashfs[0]: Bytes available: 25902080
flashfs[0]: flashfs fsck took 18 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: c4:71:fe:8f:e2:3f
Ethernet speed is 100 Mb - FULL duplex
Loading "flash:/c1140-k9w8-mx.124-18a.JA1/c1140-k9w8-mx.124-18a.JA1"...####################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w8-mx.124-18a.JA1/c1140-k9w8-mx.124-18a.JA1" uncompressed and installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Image text-base: 0x00004000, data-base: 0x007B0000
Proceeding with system init
Proceeding to unmask interrupts
SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!
%Software-forced reload
: Unexpected exception to CPUvector 2000, PC = 0x19F7C8  , LR = 0x19F718
-Traceback= 0x19F7C8 0x19F718 0x1B2DB0 0x1B3480 0x11354C 0x1C606C 0x1C610C 0x2878C4 0x1133A0 0x56C9C 0x571A0 0x1A37F0
CPU Register Context:
MSR = 0x00029210  CR  = 0x40002022  CTR = 0x00075270  XER   = 0x00000000
R0  = 0x00000000  R1  = 0x00F8E618  R2  = 0x00000000  R3    = 0x00000006
R4  = 0x00000006  R5  = 0x00000000  R6  = 0x00F8E600  R7    = 0x00A20000
R8  = 0x00000000  R9  = 0x00A322A8  R10 = 0x00A20000  R11   = 0x00000000
R12 = 0x20002022  R13 = 0x01000000  R14 = 0x007D23A4  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00113548  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000350  R23   = 0x00113548
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x00113548  R27   = 0x00000350
R28 = 0x00000000  R29 = 0x00B3A190  R30 = 0x00000000  R31   = 0x00B20000
: Unexpected exception to CPUvector 2000, PC = 0x1C54BC  , LR = 0x1A37F0
-Traceback= 0x1C54BC
MSR = 0x00029210  CR  = 0x00000000  CTR = 0x0017B9A0  XER   = 0x20000000
R0  = 0x00000000  R1  = 0x00F9A890  R2  = 0x00000000  R3    = 0x00000000
R4  = 0x001C54BC  R5  = 0x0002921B  R6  = 0x00021010  R7    = 0xBEEFCAFE
R8  = 0x00000000  R9  = 0x00B20000  R10 = 0x00000983  R11   = 0x00000000
R12 = 0x40000003  R13 = 0x01000000  R14 = 0x00000000  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23   = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x00000000  R27   = 0x00000000
R28 = 0x00000000  R29 = 0x00000000  R30 = 0x00000000  R31   = 0x00000000
=== Flushing messages () ===
Nested exception_rom_monitor call (3 times)
Unexpected exception to CPUvector 2000, PC = 1C54BC
Exception (2000)! Debug Exception (Could be NULL pointer dereference)
SRR0 = 0x001C54BC  SRR1 = 0x00029210  SRR2 = 0x00293CB4  SRR3 = 0x00021010
ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x10000000
Vector = 0x00002000  PC =  0x001C54BC  MSR = 0x00029210  CR =  0x00000000
LR =  0x001A37F0     CTR = 0x0017B9A0  XER = 0x20000000
Stack trace:
PC = 0x001C54BC, SP = 0x00F9A890
Frame 00: SP = 0x00000000    PC = 0x00174644
ap uptime is 5 seconds
using  eeprom values
ddr init done
PCIE0: link is up.
PCIE1: link is up.
1 ACCEPTED SOLUTION
5.2.157/178 and 1140 in H-reap mode = Crash = This was a big blunder with test teams failing to catch this bug.
CSCsx58514    Hreap local switching  makes 1140 reboot continuously
CSCsv67671    AP1140  crash - with IP redirection and various other configs
Bugtoolkit :
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
Move to 7.0.220.0 and you shall be fine.
Thanks..Salil
Hall of Fame Super Blue
Here's what I suspect is happening:
1.  You are running CAPWAP/LWAP image.
2.  Your AP must've crashed in the past several times;
3.  After it crashes, the AP will create a crashinfo subdirectories; and
4.  NOW, it continues to crash and continues to create MORE subdirectories until your WAP's flash gets filled up.
This is what is known as a crash-boot-loop.  The only way I can see you fix this is to convert the WAP to autonomous, erase all the crash info file (or better yet, just format the entire WAP using the command "format flash:") and convert the WAP from autonomous to CAPWAP.
Using a TFTP Server to Return to a Previous Release
Community Member
Hi,  thanks for the quick response.   I tried converting to autonomous however it is still crashing.  Here is what I tried - rebooted to rommon, did "format flash:" which was successful.  Did "dir flash:" to confirm format.  Set TFTP server IP to 10.0.0.2 and copied c1140-k9w7-tar.124-25d.JA1.tar to TFTP and renamed it c1140-k9w7-tar.default.   Rebooted AP holding mode button and it installed IOS and booted.   It's still stuck in the crash-boot-loop.  Here is the console log from a couple of loops.  One weird thing is that it shows the uptime (near end of log) as 631262959 days.  Any ideas?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.11.03 12:56:24 =~=~=~=~=~=~=~=~=~=~=~=
using  eeprom values
ddr init done
PCIE0: link is up.
PCIE1: link is up.
flashfs[0]: 146 files, 7 directories
flashfs[0]: Bytes used: 5679616
flashfs[0]: Bytes available: 26705408
Loading "flash:/c1140-k9w7-mx.124-25d.JA1/c1140-k9w7-mx.124-25d.JA1"...#########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w7-mx.124-25d.JA1/c1140-k9w7-mx.124-25d.JA1" uncompressed and installed, entry point: 0x4000
executing...
enet halted
: Unexpected exception to CPUvector 700, PC = 0x1A0C48  , LR = 0x1A0B98
-Traceback= 0x1A0C48 0x1A0B98 0x1BB90C 0x1B5F84 0x1B3D80 0x1B5014 0x7945A4 0x1816C8 0x1C1EF4 0x1ADC48
MSR = 0x00029010  CR  = 0x42008022  CTR = 0x00075614  XER   = 0x00000000
R0  = 0x00000000  R1  = 0x00C1FB1C  R2  = 0x00000000  R3    = 0x00000006
R4  = 0x00000006  R5  = 0x00000000  R6  = 0x00C1FB04  R7    = 0x00BC0000
R8  = 0x00000000  R9  = 0x00BCAB28  R10 = 0x00BC0000  R11   = 0x00000000
R12 = 0x22000022  R13 = 0x01000000  R14 = 0x00000000  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x007945A0  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x010B0020  R23   = 0x00C1FBBC
R24 = 0x00BE0158  R25 = 0x00000000  R26 = 0x00BE02FC  R27   = 0x00000001
R28 = 0x00BE1034  R29 = 0x00000000  R30 = 0x00000000  R31   = 0x010B0020
Nested exception_rom_monitor call (2 times)
Unexpected exception to CPUvector 700, PC = 1A0C48
: Unexpected exception to CPUvector 700, PC = 0x0       , LR = 0x1A2678
-Traceback= 0x1A2678 0x1A2724 0x2E69D8
MSR = 0x00021010  CR  = 0x42008022  CTR = 0x00000000  XER   = 0x00000000
R0  = 0x001A2654  R1  = 0x00C4D7B4  R2  = 0x00000000  R3    = 0x00000002
R4  = 0x00000006  R5  = 0x00000000  R6  = 0x00C4D79C  R7    = 0x00BC0000
R8  = 0x00000000  R9  = 0x00000000  R10 = 0x00000006  R11   = 0xFFFFFFFF
R12 = 0x00000000  R13 = 0x01000000  R14 = 0x00000000  R15   = 0x00000000
R28 = 0x00BE1034  R29 = 0x00C20000  R30 = 0x00000000  R31   = 0x00000017
Nested exception_rom_monitor call (4 times)
-Traceback= 0x1A2678 0x1A2904 0x2E69D8
Exception (700)! Program
SRR0 = 0x00000000  SRR1 = 0x00021010  SRR2 = 0x002EB118  SRR3 = 0x00021010
ESR = 0x08000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x14100000
Vector = 0x00000700  PC =  0x00000000  MSR = 0x00021010  CR =  0x42008022
LR =  0x001A2678     CTR = 0x00000000  XER = 0x00000000
Stack trace:
PC = 0x00000000, SP = 0x00C4D7B4
Frame 00: SP = 0x00C4D804    PC = 0x001A26A4
Frame 01: SP = 0x00C4D854    PC = 0x001A2904
Frame 02: SP = 0x00000000    PC = 0x002E69D8
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 11-Aug-11 02:58 by prod_rel_team
uptime is 4 seconds
cisco AIR-AP1142N-A-K9    (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
using  eeprom values
ddr init done
PCIE0: link is up.
PCIE1: link is up.
executing...
enet halted
: Unexpected exception to CPUvector 700, PC = 0x0       , LR = 0x0
: Unexpected exception to CPUvector 200, PC = 0x1C6618  , LR = 0x1C65C8
-Traceback= 0x1C6618
MSR = 0x00021000  CR  = 0x22008084  CTR = 0x0007494C  XER   = 0x20000000
R0  = 0x00000018  R1  = 0x00C4D69C  R2  = 0x00000000  R3    = 0x00000000
R4  = 0x00000001  R5  = 0x00000000  R6  = 0x00000000  R7    = 0x00000000
R8  = 0x00000000  R9  = 0x00000018  R10 = 0x00000000  R11   = 0x7C8803A6
R12 = 0x22008082  R13 = 0x01000000  R14 = 0x00000000  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x007A79F0  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0xFFFFFFD0  R23   = 0x00BE02E4
R24 = 0x00BDFF3C  R25 = 0x00000000  R26 = 0x00BE0284  R27   = 0x00000000
R28 = 0x00BE0254  R29 = 0x00000001  R30 = 0x00000000  R31   = 0x00000000
Unexpected exception to CPUvector 200, PC = 1C6618
Exception (200)! Machine Check
ESR: 0x08000000, BESRA: 0x00000000, BESRB: 0x00000000, BEAR: 0xFFFFFFFF
MSR: 0x00020000, SRR2: x001C6618,   SRR3: 0x00021000
Vector = 0x00000200  PC =  0x001C6618  MSR = 0x00021000  CR =  0x22008084
LR =  0x001C65C8     CTR = 0x0007494C  XER = 0x20000000
Stack trace:
PC = 0x001C6618, SP = 0x00C4D69C
Frame 00: SP = 0x00000000    PC = 0x00000000
uptime is 631262959 days, 7 hours, 37 minutes, 12 seconds
cisco AIR-AP1142N-A-K9    (PowerPC405ex) processor (revision B0) with 0K bytes of memory.
using  eeprom values
ddr init done
Community Member
I've been doing some more testing.  If I format the flash and reinstall the LWAPP recovery image where the AP can't connect to the WLC, it stays up searching for the controller.  Once it connects and downloads the image from the WLC it starts the crash loop.  I'm going to try updating the code on one of my controllers over the weekend to see if it fixes the issue.  According to the release notes, the AIR-LAP1142N was supported as of 5.2.157 and we're at 5.2.178 so it should work.
Before I upgrade, would there be any reason not to upgrade to the latest code 7.0.220 on my WLC4402?
Thanks again!
Bugtoolkit :
Thanks..Salil
He is running 7.0.220.0.
Community Member
Hi Salil,
Thanks, that was the issue.  I upgraded a test controller to 7.0.220 and the AP joined and has been running for an hour with no problems.
Leo, thanks for your help.   I'm now an expert at reimaging APs.
Bill
Re: New AIR-LAP1142N-A-K9 Insufficient Memory To Boot The Image
CPUvector 700
This is what is troubling me. I've got a funny feeling you've got a hardware issue with your flash.
Forget what I said.
2246
