No drivers for windows 7 64 bit for PI21AG
I just paid $170 for a Cisco Aironet  802.11a/b/g Wireless PCI Adapter ( AIR-PI21AG-A-K9 ).
I was suprised to discover that it doesnt have drivers for windows 7 64bit. for the price of one of these it should be able to be supported on windows 7.
ive tried to run it on compatibility mode for vista and still nothing. this is very fustrating for an expensive product.
Re: No drivers for windows 7 64 bit for PI21AG
Hi Niko,
I request you to download the VISTA drivers from the website and give a try..
Surendra
I have the same issue; the Vista drivers don't work for me, the computer hangs; what's worse is that they even hang a computer with Vista.
What can I do? This is very frustrating
thanks
the Windows Vista Drivers don´t work for me. Do you have some procedure for this?
2084
