No Heat Maps being displayed in WCS
twikel
WCS 4.2.81.0
WLC 4.2.112.0
Loc 3.1.36.0
I have a very large map with currently 40 APs placed on it. Tt will have close to 80 when completed.
Layer that are on:
AP
AP Heatmaps
Clients
Rogue APs
Resaved AP placement and recalc RF prediction. Antennas are all set to other as the 1242 are being transmitted across a Mobile Access DAS.
I'm seeing clients and rogues, but no AP heat maps. Any ideas what is happening
Scott Fella
In the layers under Access Points, you can only check 802.11a or 802.11b/g. If you have checked 802.11a + 802.11b/g then you will see no heat map.
-Scott
Fixed that and had to change AP Antennas to defualt rubber ducks. The 'Other' selection doesn't seem to have a radation pattern associated with it.
We just ran into this. we upgraded from WCS 4.2 to 5.2 and the default filters were all selected so we were not seeing the heatmaps. This was the solution for us.
