09-23-2005 12:59 PM - edited 07-04-2021 11:09 AM
Not able to change start and end date in WLSE-reports-trends
Report Name-Group Performance Report: RF Utilization
09-23-2005 09:05 PM
Are the boxes with the pulldowns there? Are you unable to use the pulldown or when you change the date in the pulldown do you not see a reflection in the results? Does this happen on other reports or just this one? Does the WLSE report that there is data available?
10-04-2005 02:02 PM
I see boxes and can select date also but as I submit the report chnage back to today date and report shows only today data. How to check data availability ?
10-05-2005 04:58 AM
The only time I have seen an issue similar to this it has been due to corruption in the database. Usually it was reported after an upgrade from 2.x to 2.11. Have you recently upgraded from 2.x to 2.11? Was the patch applied prior to upgrade?
