01-28-2004 02:57 PM - edited 07-04-2021 09:19 AM
Having some issues with mapped drives in a Novell login script. Logging in through an Access Point 1200 - the script runs, the mappings look like they are mapped. However, when you go to MY Computer on a PC Notebook - the drive is not accessable.
As soon as you plug into the wired network, things work fine.
Anyone run into this?
Ken Benich
School City of Hammond
Hammond, IN
02-23-2004 05:43 AM
Have you tried installing the latest novell client V4.9? I do have a problem connecting to the NDS before installing the latest client s/w. Took abt 5 minute before the client can connect to the Tree.
Now seems fine...
Btw i think you should know the AP does not support ipx. So if your novell server is running purely on ipx then it might be one of the problem.. ?
Hope this helps...
04-04-2004 04:23 PM
ip multicast routing
interface vlan 200
ip pim dense-mode
