Community Member
Novell and mapped drives
Having some issues with mapped drives in a Novell login script. Logging in through an Access Point 1200 - the script runs, the mappings look like they are mapped. However, when you go to MY Computer on a PC Notebook - the drive is not accessable.
As soon as you plug into the wired network, things work fine.
Anyone run into this?
Ken Benich
School City of Hammond
Hammond, IN
Community Member
Re: Novell and mapped drives
Have you tried installing the latest novell client V4.9? I do have a problem connecting to the NDS before installing the latest client s/w. Took abt 5 minute before the client can connect to the Tree.
Now seems fine...
Btw i think you should know the AP does not support ipx. So if your novell server is running purely on ipx then it might be one of the problem.. ?
Hope this helps...
Community Member
ip multicast routing
interface vlan 200
ip pim dense-mode
98
