oeap 600 - can't connect to corporate wlan
Hello!
I have some trouble with the setup of an oeap 600 ap.
The ap has joined the controller as it should and the remote-lan connection to my corporate network works well, but i can't connect to the corporate wlan.
When i check the event log on the ap it says:
*Oct 02 07:36:56.662: (Re)Assoc-Req from 00:1a:73:d2:82:8c forwarded to WLC, wired: no
*Oct 02 07:36:56.665: received assoc-rsp for wireless client, status=0011
*Oct 02 07:37:11.712: DisAssoc-Req/DeAUTH from 00:1a:73:d2:82:8c forwarded to WLC, wired: no
*Oct 02 07:37:11.713: WTP Event: Delete Mobile sent to wlc00:1a:73:d2:82:8c"
and a debug on the controller gives me:
apfMsConnTask_6: Oct 02 08:52:05.034: 00:1a:73:d2:82:7f Adding mobile
on LWAPP AP ec:c8:82:c2:3a:20(0)
*apfMsConnTask_6: Oct 02 08:52:05.034: 00:1a:73:d2:82:7f Association received from mobile on AP ec:c8:82:c2:3a:20
*apfMsConnTask_6: Oct 02 08:52:05.034: 00:1a:73:d2:82:7f Sending Assoc Response to station on BSSID ec:c8:82:c2:3a:20 (s
tatus 17) ApVapId 1 Slot 0
*spamApTask2: Oct 02 08:52:05.038: 00:1a:73:d2:82:7f Received Idle-Timeout from AP ec:c8:82:c2:3a:20, slot 0 for STA 00:
1a:73:d2:82:7f
*spamApTask2: Oct 02 08:52:05.038: 00:1a:73:d2:82:7f apfMsDeleteByMscb Scheduling mobile for deletion with deleteReason
4, reasonCode 4
Does anyone have an idea?
thanks
Everyone's tags (5)
problem solved. I had to turn off client load balancing on the wlan on the controller, and everything works  fine.
For More information on OEAP-600, please watch the "Community Tech-Talk Series" Cisco Office Extend Access Point OEAP-600
https://supportforums.cisco.com/community/netpro/wireless-mobility/begin-wireless/blog/2012/02/24/cisco-office-extend-access-point-oeap-600
Vinay Sharma
Community Manager - Wireless
Thanks & Regards
Does the OEAP-600 support redundant WLC configuration. We have 2 WLC 5508 in the network and would like to take advantage of this redundancy.
Vikas
1665
