Option 43 question
My network has two different types of AP's, the 1130 and the 1242. I am using the Cisco switches to provide DHCP information to the AP's. If I read the directions correctly, I am supposed to use two different subnets for each model of AP?
Is that correct?
1 ACCEPTED SOLUTION
Re: Option 43 question
I have 1131s and 1200 APs on the same subnet. Here is the doc I used to configure the option 43 in my DHCP server.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808714fe.shtml
Table 1 shows you the VCI you need for the 1240
Scratch this I see you are using the switch for DHCP. Yeah you will have to create different pools for each type of AP. Sorry about that.
1 REPLY
144
