Community Member
OS X client can't assoc to 1231 w/WPA2 PSK/Mac Auth
Hey all,
I have a minor issue where I am trying to enforce Personal WPA2 PSK and MAC Authentication on a 1231 AP. When the two are combined, I see Failed Authentication from the 1231 console, however when I use just WPA2 everything is fine. I have not tried using just MAC Auth. Thinking there was a bug, I upgraded code from 12.3.7 JA 2 to 12.3.8 JEB1, however this didn't resolve my issue either. Does anyone know what this could be? It works just fine from an WinXP standpoint.
I am using Mac OS X 10.4.10.
Thanks!
1 REPLY
Silver
Re: OS X client can't assoc to 1231 w/WPA2 PSK/Mac Auth
If windows works fine then I dont think there is a problem with the network. Upgrade the Mac OS client. Try disabling Aironet Extension if possible.
272
