Out put power limitation of ETSI 1300 series bridges.
Is it possible to change the regulatory domain (country specific) of 1300 series wireless bridges through Software?
Hall of Fame Super Red
Re: Out put power limitation of ETSI 1300 series bridges.
Hi Amir,
Sorry to say that this is not possible :(
That is why it is so important to order the AP/Bridge with the appropriate country code.
Hope this helps!
Rob
An irritating issue is that the output limit is 13dbi on the model with external connectors as well! We prefer to not put the APs high on antenna towers etc for maintenance reasons, buth rather use cables up to the antennas. Using 8 or 10 dbi hotspot omnis then can be difficult due to cable loss. Try to use heliax where possible but lmr400 are easier to use.
112
