Outdoor antenna coverage
Hello, folks.
My task is to give wireless coverage for outdoor environment - little garden near exit of the house (about 50x20m), so i planned to install 1300 access point, but as i understood i will need to use external antenna, since integrated one has very narrow beam (36x38 degrees).
I'm new into antenna world, can you prompt me, will AIR-ANT2460P-R (73x75) give desired coverage (especially corners) if i place point and antenna on the wall of the house.
I need only coverage, no hard speed requirements.
| Garden |
+------X-------+
~ Home ~
1 REPLY
Silver
Re: Outdoor antenna coverage
AIR-ANT2460P 6-dBi patch antenna, operates in the 2.4-GHz frequency range and is designed for use in both indoor and outdoor environments. For the further details and installation following guide may help you :
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant2460.html#wp59486
142
