Outdoor Ethernet Cable, Mesh Radios
I have a 150 ft Outdoor Ethernet Cable (AIR-ETH1500-150=) for the Mesh Radios and I would like to know if I can cut the cable to make it shorter and reterminate the RJ45 end. Does it require a special type of RJ45 connector?
Re: Outdoor Ethernet Cable, Mesh Radios
It uses Shielded Twisted Pair (STP)
And it will work fine... I do it all the time. Just use a shielded RJ-45 to preserve the shield.
Pity to cut such an expensive cable though.
You can make your own from raw parts from Tessco for a heck of a lot cheaper guys.
I didn't know that Tessco sold that kind of connector. Great information, thanks! Do you happen to have the part number for the connector? I can't find it on the Tessco site.
I don't have the part number here with me as I am working from home, but you can call their sales team and they will locate it for you.
Hall of Fame Super Red
Hi Hector/Dennis,
Is this the part you are referring to?
http://www.tessco.com/products/displayProductInfo.do?sku=390564&eventGroup=4&eventPage=1
Hope this helps!
Rob
His original question was whether he could reterminate the RJ45 after shortening the cable, and of course the answer is yes, but use a shielded RJ45 plug if you want to preserve that function.
As far as making a complete cable goes, the mating connector to a 1510 radio is an Amphenol MS3126F14-12S This is what I use to mate to the radio. I have about a dozen sitting here.
Beware that the list price of this baby is about $45 but I have been told that there are some other sources that are cheaper.
I was ordering the individual pieces including the milspec connectors and making the cables. We were using outdoor cable and ends.
194
