Community Member
Outdoor Wifi system
Hello i need info about WDS configuration o other cisco feature:
I have n°15 CISCO AIRONET 1310GE, and
n° 5 AIRONET 1142, is possible set all ap to WDS mode?
Only one SSID!
These models of AP have this feature?
TNX
Silver
Re: Outdoor Wifi system
Unfortunately, the 1142 APs cannot run in autonomous mode as of yet. Cisco has delayed the release of the software several times already, but I hear that October is the new date. Without autonomous code, you cannot run WDS.
The 1310G bridges should be able to run WDS, but that's mostly an AP feature. Are you planning to use the 1310Gs as access points? They are primarily used as bridges, which generally doesn't use WDS features.
I hope that helps,
Jeff
Community Member
tnx for reply.
Yes I need Ap for outdoor in ap feature!
please help me and please show a cisco AP wireless indor model with WDS
Thanks you
Silver
The Cisco 1131 and 1242 access points work fine as indoor autonomous APs with WDS features. And again, the 1142s will have autonomous code released eventually, though that may be several months off yet.
http://www.cisco.com/en/US/products/ps6521/index.html
http://www.cisco.com/en/US/products/ps6087/index.html
Community Member
ok tnx for the info.
Sorry,but what is autonomous code?
Silver
Cisco has lightweight and autonomous code for their APs. Lightweight code is used when you have a wireless controller. For the most part, either type of code will work on all APs. There are a few APs that are only supported in lightweight mode, such as the 1142s (currently).
For WDS services, you need to run autonomous code. However, most benefits of WDS can be obtained using lightweight APs and a controller.
http://www.cisco.com/en/US/products/hw/wireless/index.html - Cisco's Wireless homepage, where they have lots of documentation on their products.
Community Member
In conclusion, with 15 outdoor Aironet 1310GE (AP + WDS mode) and 5 Aironet 1242 Indore (AP + WDS mode) I need an external controller?
Community Member
For work, with 15 outdoor Aironet 1310GE (AP + WDS mode) and 5 Aironet 1242 Indore (AP + WDS mode) I need an external controller?
Community Member
Silver
No, sorry for the confusion. Autonomous access points do not require a controller (hence the term 'autonomous'). They run without a controller, and they run the WDS services that you're asking about.
Lightweight access points require a controller and do not use WDS. They are called 'lightweight' because they do not hold their own configuration. They receive their configurations from the controller.
Does that make sense?
Community Member
Ok tnx for info !
Then I with 15 outdoor Aironet 1310GE (AP + WDS mode) and 5 Aironet 1242 Indore (AP + WDS mode) can run my network in mode ap+wds?
Silver
That's correct. All those APs can run WDS. Make sure you order the equipment with autonomous code.
Is there any reason why you're looking to use WDS?
Community Member
I want to use WDS because I want to have only one SSID in a 200 Mter Area.
Community Member
sorry but The Cisco 1131 have internal antenna and is ok for indoor?
for - CISCO AIRONET 1310GE where is a product code of omni antenna?
Silver
Community Member
cisco 1131 is ok for outdoor!
But aironet cisco 1310GE have a wds?
for cisco 1310ge is ok antenna AIR-ANT1728?
Community Member
But aironet cisco 1310GE is ok with wds? mode?
In cisco 1131 and 1310ge wds mode is Workgroup Bridge ???
how many number of device I can use in wds mode?
598
