Output drops seem high on 801.11a radio interface
On at least 2 of our access points, it looks as though the total output drops are high for some APs that have very little client traffic on them. Our network monitoring system (OpManager via SNMP) has been generating alarms for high discard and error rates (> 90%).
Is this normal behavior? As you can see below I've had 540 drops in less than 3 minutes on my dot11radio 1 interface. The B/G radio seems OK.
MMIC-AP-RM#show interfaces dot11Radio 1
Dot11Radio1 is up, line protocol is up
Hardware is 802.11A Radio, address is 0016.9cbd.cfc0 (bia 0016.9cbd.cfc0)
MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Last input 02:57:09, output 02:56:54, output hang never
Last clearing of "show interface" counters 00:02:24
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 540
Queueing strategy: fifo
Output queue: 0/30 (size/max)
112 packets input, 5652 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 lost carrier, 0 no carrier
MMIC-AP-RM#show interfaces dot11Radio 0
Dot11Radio0 is up, line protocol is up
Hardware is 802.11G Radio, address is 0016.9cb9.cfe0 (bia 0016.9cb9.cfe0)
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/60/0 (size/max/drops/flushes); Total output drops: 3
5 minute input rate 2000 bits/sec, 4 packets/sec
5 minute output rate 25000 bits/sec, 2 packets/sec
637213 packets input, 119291746 bytes, 0 no buffer
Received 314 broadcasts, 0 runts, 0 giants, 0 throttles
671900 packets output, 334312758 bytes, 0 underruns
225 output errors, 0 collisions, 4 interface resets
288
