04-24-2006 09:44 AM - edited 07-04-2021 11:58 AM
We cannot get the Web Portal splash page to display on wireless Palm units....the site simply hangs. Is there any fixes out there for this problem. Thanks for all replies!!
04-28-2006 10:56 AM
Did you try to customize the Web authentication feature on the controller? What is the version of the firmware running on the controller?
12-22-2006 07:22 AM
Has anyone else seen this Palm/WebAuth issue or found a fix? I am seeing this on our Palm devices too. Running 4.x code with internal guest auth, laptops work just fine with the https://1.1.1.1 redirect, but the Palm just hangs. Could it be the certificate is not valid and the Palm has no way to prompt for that message like a laptop. Any ideas?
12-22-2006 10:19 AM
Look in bug toolkit for CSCsg38710. I think that bug relates to the issue. If you have an SE, you might want to contact to help push for updates on the bug (technically filed as an enhancement) and DE is looking for help identifying the underlying cause.
Ben
12-22-2006 12:49 PM
Thanks Ben, that sounds like what I'm seeing. I'll ping our SE and see what happens.
