Community Member
Password recovery on Cisco AP 1232
Hi all.
I have a Cisco 1232 AP at a remote location. It was configured by somebody no longer with the company and I have no passwords for it, no do I have a back up config.
It is using local authenticaiton.
Is there a way to do a password recovery without losing the current configuration?
Green
Re: Password recovery on Cisco AP 1232
Community Member
Scott,
Thanks for the reply.
So I can't recover the login password without blowing away the config? :(
Not if it is at a remote location, you need to use the console port. From the console port, you can perform a password recovery documented at the following URL.
http://www.cisco.com/warp/public/102/wlan/pwrec-2.html
Community Member
fredn-
Thanks for the help.
This looks like it actually erases the config currently on the AP right?
I just want to be able to set new passwords, as I don't have a spare copy of the config.
I will be on site with console access to the AP.
Community Member
The boot prom supports TFTP, so you should be able to tftp a copy of at least the non-private part of the config file to a server and reload it with the secrets changed after you wipe the AP.
Any private stuff like DSA keys or certs installed there may be lost, though.
1596
