You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
PCI350 to BR350 Association Issue
I have a BR350 with an omni connecting multiple clients. I only have issues with one client and they are using A PCI card with a 15db dish antenna pointed at the omni. They just keep reassociating all the time. While it is reassociating they consequently lose connection. It's not interference or anything like that, and I have good cables and connections. Here's a clip of my log for them:
Dec 18 13:51:35 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 13:51:50 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Authenticated
Dec 18 13:51:50 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 13:55:37 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 13:57:04 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Authenticated
Dec 18 13:57:04 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:04:00 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:04:48 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:05:28 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:14:50 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Authenticated
Dec 18 14:14:50 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:28:04 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:28:35 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:29:50 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:30:08 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Authenticated
Dec 18 14:30:08 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:30:28 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:31:01 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:32:42 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:33:41 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:36:45 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:36:55 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:38:15 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:38:47 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:39:14 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Authenticated
Dec 18 14:39:14 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:39:38 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:39:40 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:41:06 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:41:40 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:41:54 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:43:15 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:46:57 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
Dec 18 14:47:31 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Authenticated
Dec 18 14:47:31 x.x.x.x BR350-BASE (Info): Station [ClientX]xxxxxxxxxxxx Reassociated
And thats just a clip from approx. ONE hour. Any suggestions on what might be going on. Thanks
  • Other Wireless - Mobility Subjects
Bronze
Re: PCI350 to BR350 Association Issue
You have a client with a dish antenna? Is this instead of a non-root bridge? Try setting the bridge distance field under Root Radio - Advanced. It allows for longer timeout periods if the radio is far away.
Sounds like a god suggestion. I'll try it out. Thanks
113
