PEAP Configuration with IOS versus vmWorks
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
I have a Cisco Aironet 350 Series Wireless LAN Adapter running Ver 8.3.10 Firmware Along with ACU 6.0 we have it working on PEAP to a AP 350 running vmWorks ver 12.01T. However when we tried an AP 1100 Series running IOS we are unsuccessful. The AP1100 is configured as per the configuration guide.
Any suggestions?
Here is the AP 1100 config.
aaa new-model
aaa group server radius rad_eap
server 10.12.1.135 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
dot11 holdoff-time 600
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 xxxxxxxxxxxxxxxxxxxx transmit-key
encryption mode wep mandatory
broadcast-key change 300
ssid tsunami
authentication open eap eap_methods
authentication network-eap eap_methods
accounting acct_methods
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2312
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.12.0.246 255.255.252.0
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
ip radius source-interface BVI1
radius-server host 10.12.1.135 auth-port 1645 acct-port 1646 key 7 xxxxxxxxxxxxxxxxxxxxxxxxx
radius-server retransmit 3
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
Re: PEAP Configuration with IOS versus vmWorks
Nothing jumps out as wrong your best bet is to use the debugs
You have added the 1100 as a NAS in the radius server ? shared keys etc are right ?
On the radius server debugs what do you see ?
On the ap try
debug dot11 aaa process
debug dot11 aaa rxdata
I think you need to configure your key in slot 2. this is from WEP Key restrictions for WPA -- Table 9-1 in the IOS software configuration guide...
Change your config as follows:
ssid tsunami
authentication network-eap eap_methods <-TAKE OUT
guest-mode
The following link is a good guide to setting up PEAP.
http://www.missl.cs.umd.edu/Projects/wireless/8021x/
290
