Physical Port WLC
I can configure the distribution port to 100Mbps FullDuplex?
Hall of Fame Super Red
Re: Physical Port WLC
Hi Ricardo,
Q. The physical ports on the controller are currently set to operate at 1000 mbps speed. Is it possible to change this port speed to 100 mbps?
A. No, the port speed on the controller cannot be changed. These are set at 1000 mbps, full duplex speed only.
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a008064a991.shtml
Hope this helps!
Rob
Rob, but in the CLI of the wireless lan controllers, these command are available:
(Cisco Controller) >show port summary
STP Admin Physical Physical Link Link Mcast
Pr Type Stat Mode Mode Status Status Trap Appliance POE
1 Normal Forw Enable Auto 1000 Full Up Enable Enable N/A
2 Normal Disa Enable Auto 1000 Full Down Enable Enable N/A
3 Normal Disa Enable Auto 1000 Full Down Enable Enable N/A
4 Normal Disa Enable Auto 1000 Full Down Enable Enable N/A
(Cisco Controller) config>port physicalmode 1 ?
[100h/100f/10h/10f] Enter port speed and duplex setting.
Even though those commands are there they will not work. GBIC ports like these cannot be changed from 1G full.
Hi Ricardo -
What model of WLC is this?
255
