Please need your help
i have a simple wireless topology:  nm-wlc module(in router)-->switch-->1130 series ap
router with intergrated nm-wlc module
switch connected to router and to access point
access point 1130 series
the problem is that access point cannot join to wlc, i used debug events and packets on wlc and he doest see any request
so here is configs(also attached it):
wlc configs/
piece from auto-install/
interface controller ip: 172.16.1.250 255.255.255.0
management interface ip address: 172.16.1.10 255.255.255.0
management interface default router: 172.16.1.250
vlan=0
port=1
management dhcp server ip address 172.16.1.10
Ap manager 172.16.1.11
virtual 1.1.1.1
sside network: Skyrim
config interface create v120 20
config interface create v121 21
config interface address v120 172.16.20.254 255.255.255.0
config interface address v121 172.16.21.254 255.255.255.0
wlan create 20 v120
wlan create 21 v121
wlan interface 20 v120
wlan interface 21 v121
interface dhcp v120 172.16.20.1
interface dhcp v121 172.16.21.1
wlan security 802.1x disable 20
wlan security 802.1x disable 21
Switch/
interface f0/11
description connected to LWAPP AP
switchport access  vlan 100
switchport mode access
interface f0/25
Description connected to Router
Switchport mode trunk
Router
Ip dhcp excluded-address 172.16.100.1 172.16.100.100
ip dhcp pool lwapp-ap
network 172.16.100.0 255.255.255.0
default router 172.16.100.1
option 43 ascii "172.16.1.10"
ip dhcp pool client-20
network 172.16.20.0 255.255.255.0
default-router 192.168.16.1
ip dhcp pool client-21
network 172.16.21.0 255.255.255.0
interface f0/0
description connected to ap
Interface f0/0.100
encapsulation dot1q 100
ip address 172.16.100.1 255.255.255.0
interface intergrated-service engine 1/0
ip address 172.16.1.250 255.255.255.0
interface intergrated-service engine 0/0.20
encapsulation dot1q 20
ip address 172.16.20.1 255.255.255.0
interface intergrated-service engine 0/0.21
encapsulation dot1q 21
ip address 172.16.21.1 255.255.255.0
if need i can show full configs
thank you
Everyone's tags (1)
1 REPLY
Re: Please need your help
The only AP that take ASCII in option 43 were the old 1000 series ap. for all others it needs to be in hex. So your option 43 should be
Option 43 hex f104.ab10.010a
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
245
