Poblem after upgrade Prime NCS to Infrastructure
I just upgrade Prime NCS  1.1.1.24 to 2.0 becuase we had several problem with NCS Aplication, after this upgrade I can´t longer see the Access Point on the floor maps, the APs are still assigned to the map and if I try to edit the location or asign APs to a new map, the aplication keeps loading but doesn´t do anything. I follow the quick installation guide for upgrading and installed the ncs_1_1_1_24-Update.13.4.tar.gz patch.
thanks for your help
Re: Poblem after upgrade Prime NCS to Infrastructure
Unless you need some specific 2.0 feature you should run 1.3 with the latest patch.
do you know if is it posisible to do a downgrade from Prime 2.0 to Prime 1.3
thanks a lot.
Hall of Fame Super Silver
You should be able to, but your best bet is to bring up a new VM on PI 1.3, and rehost the license.  Then you can export the map's and import the map's on your new VM PI 1.3.  If you try to downgrade, make sure you take a snapshot of the VM, so you can revert in case it doesn't work.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Would you mind explaining your reasoning?  Just cut a PO for 2.0 today, going to be upgrading from 1.1.1.24.
I have remove the aps and add them again and the they appear again in the maps
317
