07-14-2014 09:39 AM - edited 07-05-2021 01:13 AM
I want to connect a remote office using a bridge between buildings.
Can i cover a range of 800meters using Aironet 1532E with AIR-ANT2588P3M-N antennas?
what is the maximum distance between points?
07-15-2014 12:05 PM
Hello Daniel,
It depends on a number of factors. Eg, LOS, the data rate etc.
And one can't calculate the true signal attenuation for any area.
So I'd suggest you to carry out a site survey.
Hope that helps.
07-15-2014 02:59 PM
yes it will support just the LOS should be clear..
