Port configuration question (APs and VoIP)
We have Cisco 5508 controller and 1130 LAPs (in h-reap mode). We are deploying wireless VoIP phones in the network and the question is,
do I have to configure the following line on the switchports the APs are connected to?
switchport trunk native vlan 333
switchport mode trunk
switchport voice vlan 50
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust dscp
auto qos voip trust
Petri
1 ACCEPTED SOLUTION
Re: Port configuration question (APs and VoIP)
I'm sorry but I totally differ from Rob's reply.
The command "switchport voice vlan" only works for wired phones.
Sine the wireless traffic is all capwap encapsulated, a switch will make no difference about phone traffic.
How to have a voice vlan => Simply have a separate SSID that will link to a voice-specific vlan
How to have Qos=> Follow the document pasted by Rob and also the config guide of WLC. Basically, have the ssid as platinum qos, wmm enabled and map to CoS 6 and you should be good to go.
Nicolas
Don't forget to rate answers that you find useful
Hall of Fame Super Red
Hi Petri,
Yes, you will need the Voice vlan config
Have a look at this good design "White Paper";
http://ciscosystems.com/en/US/solutions/collateral/ns340/ns394/ns348/net_implementation_white_paper0900aecd804f1a46.pdf
Cheers!
Rob
Nicolas
Hall of Fame Super Gold
Switch port configurations for LWAP/CAPWAP is basically an access port.
switchport access vlan
switchport mode access
spanning-tree portfast
In this case the APs are in h-reap mode, so that's why ports are trunk. My first thought was, that the line is not needed, so I'll have to trust Nicolas on this one. Thank you for the answers.
Br,
Petri
478
