Pre-login with Cisco ADU
owensm
Is it possible to setup pre-login on XP, Cisco a/b/g card theADU with WPA2/PEAP. No Third party tool. If so, please provide details.
a-vazquez
Level 6
Level 6
You can make your Access point to authenticate the Client cards
Also depending on the card that you use if the supplicant will support pre logins. Most Intel wireless cards supports pre logins
