Community Member
Printing issue over wireless connection AP1300
We have 2 1300 external AP's set up as workbridge and none workbridge. All the thin clients work fine it is the two HP printers that are causing troubles. the AP's are setup as default nothing really changed in the config. This issue is that the two printers have static IP's and work as soon as you turn them on. Leave them for 20 minutes and you can print to them but nothing comes out. Power save is off idle time is low any thoughts
1 REPLY
Anonymous
N/A
Re: Printing issue over wireless connection AP1300
Is it a printer or Print server? If it is a print server we will have to create a TCP port for the print server. Refer manufacturer's document or contact manufacturer for this.
143
