12-06-2013 08:06 PM - edited 07-04-2021 01:23 AM
I am having trouble to get AIR CAP1602I-C-K9 attached to a 5508 WLC running code 7.4.110.0
Here is what I got from the AP logs:
Extracting files...
ap1g2-k9w8-mx.152-2.JB2/ (directory) 0 (bytes)
extracting ap1g2-k9w8-mx.152-2.JB2/K5.bin (75790 bytes)!!!!
*Dec 6 15:09:23.011: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec 6 15:09:23.535: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.10.100 peer_port: 5246
*Dec 6 15:09:23.535: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.10.100
*Dec 6 15:09:23.535: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Dec 6 15:09:23.535: %CAPWAP-3-ERRORLOG: CAPWAP!
extracting ap1g2-k9w8-mx.152-2.JB2/ap1g2-k9w8-mx.152-2.JB2 (9202946 bytes)!!!!!!!!! SM handler: Failed to process message type 10 state 5.
*Dec 6 15:09:23.535: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Dec 6 15:09:23.535: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 172.16.10.100perform archive download capwap:/ap1g2 tar file
*Dec 6 15:09:23.583: %CAPWAP-6-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*Dec 6 15:09:23.587: Loading file /ap1g2...
*Dec 6 15:09:24.007: %LINEPROTO-5-UPDOWN:!!!!!!!!!!! Line protocol on Interface Dot11Radio0, changed state to down
*Dec 6 15:09:24.063: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up!!!!!!!!!!!
*Dec 6 15:09:25.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up!!!!!!!!!!
*Dec 6 15:09:26.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Premature end of tar file
ERROR: Problem extracting files from archive.
Download image failed, notify controller!!! From:7.4.1.37 to 7.4.110.0, FailureCode:3
archive download: takes 63 seconds
*Dec 6 15:10:26.851: capwap_image_proc: problem extracting tar file
after that the AP reboots and do same process over and over again,
Please help..
Many Thanks,
Barth
Solved! Go to Solution.
12-06-2013 11:16 PM
AIR-CAP1602I-C-K9
Configured Country............................... US - United States
Your AP has the wrong REGULATORY DOMAIN.
This is why the AP won't join the WLC. Your AP has the regulatory domain of "-C" which is countries like Pakistan, China, Indonesia, Macau, etc. Your WLC is set for US.
12-06-2013 11:28 PM
Refer to this document: Wireless LAN Compliance Status
12-06-2013 08:09 PM
Here is the info about AP and WLC:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... WLC1-AP
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 172.16.10.100
Last Reset....................................... Power on reset
System Up Time................................... 0 days 4 hrs 12 mins 28 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
External Temperature............................. +28 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ F8:72:EA:EF:2E:A0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, Power Off, Fan On
Maximum number of APs supported.................. 100
AP4403.a7fd.f040#sh ver
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 04:45 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
AP4403.a7fd.f040 uptime is 4 minutes
System image file is "flash:/ap1g2-k9w8-mx.152-2.JB/ap1g2-k9w8-mx.152-2.JB"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-CAP1602I-C-K9 (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1711ZJNW
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.4.1.37
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 44:03:A7:FD:F0:40
Part Number : 73-14671-04
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC16517DZ1
Top Assembly Part Number : 800-38552-01
Top Assembly Serial Number : FGL1711ZJNW
Top Revision Number : A0
Product/Model Number : AIR-CAP1602I-C-K9
Configuration register is 0xF
AP4403.a7fd.f040#sh inventory
NAME: "AP1600", DESCR: "Cisco Aironet 1600 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP1602I-C-K9 , VID: V01, SN: FGL1711ZJNW
12-06-2013 11:16 PM
AIR-CAP1602I-C-K9
12-06-2013 11:28 PM
12-06-2013 09:24 PM
Did you check u hv configured AP policies on ur WLC? What is "show auth-list" output looks like on ur WLC?
If so u need to add AP eth MAC on to this list.
12-07-2013 01:13 AM
Hi Leo,
i already set WLC regulatory domain to ID (Indonesia) but the error still occur, so i change it back to US..later on I will try it again..
Hi Rasik,
Yes i already add AP MAC to the authentication list..
12-07-2013 04:30 AM
Ok, if you did, can you please post the output to the WLC command "sh sysinfo"?
12-07-2013 04:43 AM
HI Barth,
1.Please remove the old image from AP.
Connect Console cable into the AP and run the command "delete /f /r flash:ap1g2-k9w8-mx.152-2.JB2" and try again.
2. Please reboot the WLC(before reboot please save the config with right regulatery domain)
Hope it helps.
Dont forget to rate helpful posts.
12-07-2013 04:53 AM
Hi all,
Thank you for the advices but I won't be able to do it untill Monday (office hour)
I'll post the result as soon as possible.
Many Thanks,
Barth
12-09-2013 05:35 AM
Hi all,
it seems the code/firmware of the WLC is corrupted,
i try to join the AP to another 5508 WLC with same configuration (regulatory domain=ID) and it joins smoothly..
Thanks for your help, really appreciate it
Barth
