problem to connect to aironet 1240 via mobiles
I have an network with aironet 1240, I can't connect to wifi with my mobiles machine
event log  :
1 March 1 03:24:14.066 Information Interface Dot11Radio0 , Station 0010.3900.0ae7 Associated KEY_MGMT [ NONE ]
2 March 1 03:24:13.833 Warning Packet to customer 0010.3900.0ae7 Reached max retries , Removing the customer
3 March 1 03:24:13.829 Information Interface Dot11Radio0 , Deauthenticating Station 0010.3900.0ae7 Reason : Previous authentication no valid along
4 March 1 03:24:13.828 Warning Packet to customer 0010.3900.0ae7 Reached max retries , Removing the customer
in association the IP address is 0.0.0.0 but my devices  have a fixed IP address 10.10.2.24
my config is:
! Last configuration change at 2:45:41 UTC Mon March 1, 1993
Version 15.2
no service pad
the service timestamps debug datetime msec
the service timestamps log datetime msec
the service password-encryption
hostname ap
logging rate -limit console 9
enable secret $ 5 $ 1 $ mJy0 vOeSPnGp6i1qle.aON.2r .
no aaa new -model
ip cef
dot11 syslog
dot11 vlan -name vlan 1 bechbech
dot11 ssid bechir
   vlan 1
   open authentication
   guest- fashion
   infrastructure - ssid optional
   ip redirection host 10.10.2.5
dot11 network -map
dot11 arp cache optional
dot11 priority -map AVVID
Cisco username password 7 062506324F41
bridge irb
Dot11Radio0 interface
 no ip address
 ssid bechir
 antenna gain 0
 speed basic -1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0 . m1 . m2 . m3 . m4 . m5 . m6 . m7 . m8 . m9 . m10 . m11 . m12 . m13 . m14 . m15 .
 power local client
 channel 2437
 station -role root
 dot11 dot11r pre -authentication over- air
 no dot11 extension aironet
 infrastructure -client
Dot11Radio0.1 interface
 encapsulation dot1Q 1 native
 bridge-group 1
 bridge-group 1 subscriber -loop -control
 bridge-group 1 spanning- disabled
 bridge-group 1-port - protected
 bridge-group 1 block -unknown- source
 no bridge-group 1 source -learning
 no bridge-group 1 unicast - flooding
GigabitEthernet0 interface
 no ip address
 half duplex
 auto speed
 no keepalive
GigabitEthernet0.1 interface
 bridge-group 1
BVI1 interface
 ip address 10.10.2.5 255.255.255.0
ip forward -protocol nd
ip http server
no ip http secure-server
ip http help- path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip access- list extended bbb
 permit ip any any
 permit ip any 0.0.0.5 255.255.255.0
bridge 1 route ip
line con 0
line vty 0 4
 local login
 transport input all
end
thank you in advance
Everyone's tags (1)
Hall of Fame Super Gold
 permit ip any any
Huh?  What is this ACL for???
Your configuration looks ... odd.  What exactly are you trying to do?
this is a default value, I
Hello Leo,
this is a default value, I changed nothing
it is a local network of more mobile devices (do not support networks secured wpa, wep etc ...) that connects to a local server, all machine have IP Addresses 10.10.2.x ,I want that the access point accepts only machine that have 10.10.2.x Address
what I need to change?
Here my need
thank you for helping me
1000 thanks :)
Hello Leo,this is a default
Hello Leo,
Here my need
1000 thanks :)
I think my problem is related
I think my problem is related to the decryption
how fix it?
client status below:
79
