07-28-2014 04:53 PM - edited 07-05-2021 01:17 AM
Good day, experts.
I have two WLC 5508, it works in HA mode. For HA i have to upgrade one of WLC to version 7.4.121.0.
After that one AP1131 starts work very strange. The power of 2.4 radio always was on level 17dBm.Now it is changing everytime.
And as result: before this AP worked with 19-25 clients. Now it can not service more than 15 clients.
I think, all other APs works well. But i'm not sure. Does anybody know what it is could be?
07-28-2014 11:21 PM
you can adjust the power level manually.
Click Wireless > 802.11b/g Radio and a list of associated access points appears.
Choose the desired access point from the displayed list and click Configure(on far right side). The radio settings page appears.
You will see Tx Power Level Assignment field, and click Custom. Custom indicates that the radio output power is manually controlled by the Tx Power Configuration setting field and you can change the power setting to one.
2.4 GHz side power levels are .
1 = 20 dBm / 100mW
2 = 17 dBm / 50mW
3 = 14 dBm / 25 mW
4 = 11 dBm / 12.5 mW
MOre info about adjusting channels and power levels:
http://www.my80211.com/home/2009/10/30/what-you-need-to-know-about-tx-power-and-80211a-5ghz-on-a-ci.html
Dont forget to rate helpful posts
07-29-2014 02:44 AM
Please verify the similar issue:
https://supportforums.cisco.com/discussion/11012756/tx-power-levels-are-low-after-wlc-upgrade-70980
07-29-2014 09:35 PM
Thank you Sandeep Choudhary. I tried to change power level manually. My problem is looks like link that mohanak post. But one thing is not correct, i have upgraded from 7.0.116 to 7.4.121.
In my situation after that upgrade power level was down on all APs.
08-22-2014 02:04 PM
Please verify the compatibility of WLC and AP:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
