Problem with EAP-SIM Authentication
ittichai_a
Hi all
I have doing EAP-Sim authentication with WLC 5508, client mobile is samsung galaxy 2, Radius proxy (Car).
So, i get message from WLC (Debug) which show the message like mobile do not going authentication state. That will make the mobile do not authentication, so, i have attach file or log also. Then, if anyone know or any idea, please help me
Thanks alot
Please see my log in attach file
Nicolas Darchis
Your mobile phone is not responding to the EAP identity requests sent by the WLC so it looks like a misconfig on the phone.
Moreover, it seems that you configure your eap identity request timeout to be something like 2 minutes ? That's best reduced to something like 10 seconds or so.
Hi Nicolas
Thanks with your support, so, i may say that it is the first time to do EAP-SIM authentication but i may not sure that i have correct to do configuration also on mobile and wlc. Then, do you have any idea or recommend to share to me ?
Because right now, I do not know what is the problem and how to solve it at all.
The WLC acts as a authenticator and it doesn't care which EAP type you use. The WLC is a "pass through"
What radius server are you using ? Have you tested this with a client different from your tablet ?
Well, what about client or mobile device ? which Eap-authentication to using? or it doesn't care also eap type also, correct?
We using Car Radius proxy.
Well, i will going to try with nokia.
Note: I may need some resarch or any document how to implement it such as WLC and mobile device
anyone have or can share, please help T_T
Best Regards
