12-01-2008 10:38 AM - edited 07-03-2021 04:50 PM
I have a WLC 4402 and LWAPs 1240, a Laptop Dell is working properly but when I introduce an LWAP 1130 the laptop goes down until 1Mbps instead of working at 54Mbps. The Wireless card in the laptop is a mini_pci inalambrica wlan 1505, Does somebody have an idea or can give me an advice?
12-02-2008 06:37 AM
Usally upgrading the client firmware fixes that issue, if not, then look at your data rate settings, etc.
12-02-2008 03:38 PM
So you connect at 54Mbps.. then it will slowly drop to 1Mbps and disconnect and then reconnect? Typically any driver over 2007-2008 should work and as the 1505 is new you shouldn't have that issue. Then under the driver settings make sure it is set to CAM mode. Because the signal is so strong the client card is powering itself down slowly and degrading performance. Also I would recommend changing the roaming sensitivity to not roam. Also I recommend setting transmit power to max.
