09-29-2013 11:44 PM - edited 07-04-2021 12:58 AM
When i connect ap(AIR-CAP1602I-E-K9) to wlc ,the error appears below
*Mar 1 02:05:05.612: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 02:05:05.616: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC_PP'running version 7.0.98.0 is rejected.
*Mar 1 02:05:05.616: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 02:05:05.616: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 02:05:05.616: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar 1 02:05:05.616: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.44.0.3
In my company have any LAP1041N-E-K9 ap. It work normally with wlc5508 with version 7.0.98.0.
If i upgrade software on wlc to 7.4.100.0 , any LAP1041N-E-K9 can work normally ?
Thank you for any answers.
09-30-2013 07:31 AM
Yes 7.4 supports the 1040 series of ap
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn74.html#wp1048617
Steve
09-30-2013 09:49 PM
In this error , i must update to 7.4 only ? what other choices i can do ?
09-30-2013 10:12 PM
Yes. You either update to this level of firmware or you don't use your 1600 AP. Your choice.
09-30-2013 11:17 PM
If you like you can go to 7.5.102.0 as well, any thing above 7.4.x should be fine
